  • 1 Reply
  • 1579 Views
arlcomter
I have a base station that I've factory reset several times, but I still can't see/setup.
Lights:
Power - Green
Internet - Green (flashing occasionally)
Camera - Amber
Router: Orbi RBR40
The VMB3500 has obtained a local IP and is visible in the connected devices list.
Factory resets appear successful: After 10 seconds, the lights flash amber and a minute or two later, I have a Green, Green, Amber light pattern again.
I've tried to connect via app, and web interface.
I've tried setting up a new Arlo account, then attempting to add the device.
Every time, I get the error "No Arlo devices found."
The device did work at one point. I had a doorbell and camera connected. Within my Arlo account, I no longer have any devices registered as I removed them all after the camera's battery died.
I was hoping to fire this up again with some better batteries.
Any suggestions?
I recently had an issue like this that was cured by using a different base. No idea what was wrong with the first one but hardware issues happen. Contact support using the link at the bottom here to invoke your warranty.
