I want to add my wife but I receive an error ‘arlo is currently unavailable’. I tried it also by using the web page, but the same error message.
It worked before, but after resetting the home base this problem started. I tried to hard reset the whole system, but nothing helps. Can you help me?
We appreciate everyone's patience about this. A cloud fix has been released that resolves this issue. This fix is automatically applied and does not require any interaction with your Arlo system. If you're still experiencing the issue, please let us know.
Have you tried another device or a web browser?
Hi Lynxmania and Bartmieke,
Are you still seeing this error? Is this happening when you're on cellular data and/or WiFi? What phone device are you using? And could you show a screenshot that shows that error as well?
Hi TomBaki,
Is this happening when you're on cellular data and/or WiFi? What phone device are you using? Have you tried this on the web client on your computer? And could you show a screenshot that shows that error as well?
Hello,
It doesn't matter if I'm on Wifi or mobile data network. The error stays... I also tried it on the internet on a PC, but the problem stays... I'm using an Iphone. Ive added a screenshot when I tried it on a pc.
I'm also in Belgium...
Tried on Chrome/internet explorer, several phones. My parents in law have the exact same issue. I feel Arlo should put more resources to tackle this issue!
I received a message from Arlo services. The'll look into it and I'll post the solution (if any)
