  • 13 Replies
  • 9308 Views
  • 5 In Conversation
Retired_Member
Not applicable
Hello,
I want to add my wife but I receive an error ‘arlo is currently unavailable’. I tried it also by using the web page, but the same error message.
It worked before, but after resetting the home base this problem started. I tried to hard reset the whole system, but nothing helps. Can you help me?
JessicaP
We appreciate everyone's patience about this. A cloud fix has been released that resolves this issue. This fix is automatically applied and does not require any interaction with your Arlo system. If you're still experiencing the issue, please let us know.
13 REPLIES 13
Bartmieke
When i go to settings, grant access and fill in the name and emailadres, everything works but when i push send invite, he tells me arlo service is unavailable, try again later. It’ s now 5 days like this....
Have you tried another device or a web browser?
Bartmieke
Yes, i’ve tried it on iphone, mac and windows. Same message.
JessicaP
Hi Lynxmania and Bartmieke,
Are you still seeing this error? Is this happening when you're on cellular data and/or WiFi? What phone device are you using? And could you show a screenshot that shows that error as well?
TomBaki
I have the same problem for months now. I made a couple of cases but nothing has changed. It’a strange it takes so long to fix? Now my wife can’t use the system. I hope Arlo team takes action. They told me all users in Belgium were affected
JessicaP
Hi TomBaki,
Is this happening when you're on cellular data and/or WiFi? What phone device are you using? Have you tried this on the web client on your computer? And could you show a screenshot that shows that error as well?
Retired_Member
Not applicable
Hello,
It doesn't matter if I'm on Wifi or mobile data network.  The error stays...  I also tried it on the internet on a PC, but the problem stays...  I'm using an Iphone.  Ive added a screenshot when I tried it on a pc.
Retired_Member
Not applicable
I'm also in Belgium...
TomBaki
Tried everything, even used a VPN on an American server because the issue is related to Belgian users.
Tried on Chrome/internet explorer, several phones. My parents in law have the exact same issue. I feel Arlo should put more resources to tackle this issue!
Bartmieke
I’ve the same problem, also located in Belgium.
Retired_Member
Not applicable
I received a message from Arlo services.  The'll look into it and I'll post the solution (if any)
JessicaP
Retired_Member
Not applicable
It works! Thank you for the fix
