Can't access Arlo on Chrome or Edge
I can't enter Arlo whether on chrome or edge, all i get is a banner on top with nonsense message about flash player.
Flash player is on in both browsers settings.
If someone has any solution i would be very grateful.
Try Firefox. Also, try deleting your web cache/cookies for the Arlo site.
Having the same problem for months orange banner about flash click on same problem nothing works tried everything
We could use more detail as to what you've tried and what you see. There are two different issues here 1) not being able to log in and 2) Flash.
1) Recent issues have popped up when using Kaspersky antivirus. Do you use that? If so, you have to configure Kaspersky to allow access to arlo.netgear.com. A search her on "Kaspersky" should give you tips.
2) For both Edge and Chrome, you get a banner about Flash needing to be updated. Click on the "click here" and you should get a pop-up to allow Flash to run on the site. Note that if you quit the browser rather than minimizing it you'll need to do that all over again next time you access Arlo.
Safari shows the same thing. Must allow Flash. When will Arlo ditch Flash!
i have read what they say to do nothing works
Thank you for the helpful hint, it was my Kaspersky and Google Chrome.
In case someone else struggles with the same issue, try to do as follows,
1. Go into Kaspersky - settings - protection - web anti-virus - advanced settings - configure trusted URLs and add https://arlo.netgear.com/ (Thank goes to the Redmoonstar)
2. Go into Chrome settings and set the web address as an exception to the Flash blocking
chrome://settings/content (Thank goes to the steve_t)
Thank you everyone for the answers! Good luck for all struggling to find solution!
Do you have the latest Chrome installed? The latest versions can't be set this way - click on the "click here" link in the Flash warning banner on the Devices tab and allow Flash to run.
