Can i use my NAS home network for storage or any exteranal hard drive.
  • 4 Replies
  • 5938 Views
v43Amarnath
No...and YES depends on base unit
The Arlo base does not support any local recording
The Arlo PRO (base ) supports only local record thru it's usb port to a usb drive max size is 1TB I believe ( fat 32 format )
v43Amarnath
I don't have Arlo pro but base station which i got also have usb port so i can also use to for local storage.
v43Amarnath
The Model : VMS3330
Those ports have never been enabled. If you want to record locally on wireless cameras you must use the Pro base.
