One camera offline orange light
If I "reset the base station" what does that mean and will that affect the other cameras? Do I have to re-sync them all? I tried pressing the sync button on the problem camera- orange light flashed for a second. . Then nothing.
Yes, resetting the base will require a whole new setup. However, that doesn't seem to be required since you see the camera LED flash amber. I'll wager you do, in fact, have weak/dead batteries which are noted by the LED flashing a slow amber. Use a fresh set of batteries or swap with another camera to prove this.
99% sure it's not that.
A factory reset is a last ditch move. You usually don't need to do this but it's available.
AmyNicole,
A reset (or factory reset) would require you to go through the setup process again adding the base station to your account and syncing all cameras. This doesn't seem necessary to resolve the issue you are describing.
A reboot of the base station (by pressing the on-off button) is a troubleshooting step that could be taken here that would not require any additional changes.
As suggested by jguerdat, it sounds like this is a low/depleted battery issue (slow flashing amber camera LED) and could be resolved by installing a fresh set.
Unfortunately, you may have to remove the cameras from Settings, My Devices and resync them.
What you said did cause the led light to blink blue for a bit : when I deleted the camera from the account and removed the battery and plugged it into my pc with just the usb cable. Next, I tried to sync and the camera worked as long as it was plugged in to the cabloe. When I placed the battery back it started to flash orange again. Today another camera that worked for two days is saying it is offline and I had to resync. Do you think my batteries are being drained for some reason or has the camera battery gone bad? I am using the square rechargable batteries that come with the camera. This system seems extremely unreliable, do you think I should return it? I can't go through this every few days...
Please let me know what the contact number is for customer service, I tried to find it and all I found is this FAQ and Message Board.
Thank you so much for helping
