Can You Select Which Cameras To Put On The Cloud & Which Not To?
  • 1 Reply
  • 1135 Views
stlcardinals99
Can you select witch cameras too put on the cloud and witch not too?
steve_t
Master Master
No. By design, all cameras should be sync'd and record to the cloud. You cannot have some recording to the cloud and others not. You may be able to have a workaround that meets your needs if you have a second Pro base station that you remove from internet access after setting up the cameras but the system is not designed to be used in this way and you do so at your own risk
