Can I upgrade My Subscription?
I have the basic subscription is there anyway to upgrade?
From the kb
https://kb.arlo.com/1215141/How-do-I-change-or-cancel-my-Arlo-subscription-plan
To change or cancel your Arlo subscription plan:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
- Tap or click Settings > Subscription.
- If you are using the Arlo app, tap Edit Account.
- To change or cancel your subscription, tap or click Upgrade Now or View Plans.
Otherwise, select Manage CVR if you only want to add or change a CVR subscription. - Choose the services that you want to add or remove.
If you want to cancel your Arlo subscription, select the free Basic plan. - Tap or click Check Out.
- If prompted, enter your billing information and tap or click Continue.
- Read the summary of the changes to your account and confirm that everything is correct.
If you are removing a subscription from your account, you see an automatic credit for any unused portion of your subscription. - If you are using the Arlo app, tap Complete Payment.
If you are using a computer, click Complete Change.
