Can I upgrade My Subscription?
  • 1 Reply
  • 3255 Views
candyse
I have the basic subscription is there anyway to upgrade?
steve_t
Master Master
From the kb
https://kb.arlo.com/1215141/How-do-I-change-or-cancel-my-Arlo-subscription-plan
To change or cancel your Arlo subscription plan:
  1. Launch the Arlo app or log in to your Arlo account at my.arlo.com.
  2. Tap or click Settings > Subscription.
  3. If you are using the Arlo app, tap Edit Account.
  4. To change or cancel your subscription, tap or click Upgrade Now or View Plans.
    Otherwise, select Manage CVR if you only want to add or change a CVR subscription.
  5. Choose the services that you want to add or remove.
    If you want to cancel your Arlo subscription, select the free Basic plan.
  6. Tap or click Check Out.
  7. If prompted, enter your billing information and tap or click Continue.
  8. Read the summary of the changes to your account and confirm that everything is correct.
    If you are removing a subscription from your account, you see an automatic credit for any unused portion of your subscription.
  9. If you are using the Arlo app, tap Complete Payment.
    If you are using a computer, click Complete Change.
