I have a VMB3500r4 system. It does not have a base that allows for the siren. Can I just upgrade the base and keep the current cameras and is it difficult to do. I do have a subscription plan.
Yes you can. After purchasing and adding the new base to your account, remove the cameras from the old base and add them back to the new one. I have done this several times. You can then remove the old base from your account if so desired.
Brian
Thank you. I have 8 cameras which base would you recommend?
model 4000 for the Pro/Pro2
There is no siren built into the hub for the Ultra system. So it has to be Pro 2. Until Arlo comes up with a standalone alarm.
Just another user
