  • 4 Replies
  • 5069 Views
  • 2 Likes
Hike
I have a VMB3500r4 system.  It does not have a base that allows for the siren.  Can I just upgrade the base and keep the current cameras and is it difficult to do.  I do have a subscription plan.
brh
@Hike,
Yes you can. After purchasing and adding the new base to your account, remove the cameras from the old base and add them back to the new one. I have done this several times. You can then remove the old base from your account if so desired.
Brian
Hike
Thank you.  I have 8 cameras which base would you recommend?
model 4000 for the Pro/Pro2
michaelkenward
Sensei Sensei
Sensei
There is no siren built into the hub for the Ultra system. So it has to be Pro 2. Until Arlo comes up with a standalone alarm.
Just another user
