Can I do a hybrid schedule/Geofencing mode?
  • 4 Replies
  • 4058 Views
MarkN2016
What I want is for geofencing to be active throughout the daytime, to accommodate my comings and goings, but from 11:00 pm to 6:00 am, I would like it to switch to armed for that entire time period. Seems simple enough to me. Is it doable?
MarkN2016,
This can be done by setting up your Schedule as desired and then selecting the schedule mode in your Geofencing settings (Home or Away).
Edit your Geofencing settings and take a look at the Home and Away options for more information.
MarkN2016,
MarkN2016
Thanks for the reply! I need some clarification though: If I set the geofencing mode to "schedule" for away and home, then it goes by the schedule I've set as "armed" between 11 at night and 6 in the morning, but off the rest of the time. So, during the day, when I leave home, it will go to the schedule which tells it to NOT be armed at that time, correct? I'm confused. Sorry.
MarkN2016,
From what you've described, it sounds like you would want your Geofencing "Away" setting to Armed. This will mean your system is always Armed when you are away.
Set your "Home" mode to schedule and when you are at the home location, the schedule will determine if your cameras are Armed or not based on what you have set up in the schedule.
MarkN2016
Thanks so much!
