MarkN2016,
This can be done by setting up your Schedule as desired and then selecting the schedule mode in your Geofencing settings (Home or Away).
Edit your Geofencing settings and take a look at the Home and Away options for more information.
MarkN2016,
MarkN2016,
From what you've described, it sounds like you would want your Geofencing "Away" setting to Armed. This will mean your system is always Armed when you are away.
Set your "Home" mode to schedule and when you are at the home location, the schedule will determine if your cameras are Armed or not based on what you have set up in the schedule.
