Can I add my Arlo cameras to my NETGEAR Hawk as Base Station?
  • 2 Replies
  • 1230 Views
Hbahouh
Is it still i can add my arlo cameras with my netgear hawk as base station ? Or i must use arlo base station instead of
Hbahouh
Because there is a while i can not add my arlo cam with netgear as basestation
TMK, you can no longer connect the cameras directly to the router ( that SW was phased out a while back due to problems )
If it is an Ethernet issue, you can use an wifi extender with a port and plug the base in there.
