Can I use Arlo vmc3030 with base station vmc3000
All the wireless cameras work with all the bases. When syncing, be sure to only briefly press the base sync button - don't hold it. What are the LEDs on both the base and camera showing?
But there do not connect
Can it be that the mobile ( with the app on it ) needs to be on the WiFi of the base ?
YES
Any idea why?
You only need to be on WiFi to claim the base initially. After that you don't even need to be using the app or web - just briefly press the base sync button and then the camera sync button. I do that all the time.
If nothing is working, swap at the store.
But now I try to connect and I forgot the password !
What do I do ?
Thanks !
What are you trying to connect to? I'm confused about what you're trying to do.
I am trying to add new camera to existing. Base
In order to connect the device I need to connect the iPhone ( with the app on it) to the Netgear network ( the base internal network ) no?
All you really need to do to sync a new camera with an existing base is to briefly press the base sync button (don't hold it for 2 seconds) and then press the camera sync button. It should be that simple. You don't need to use the app at all.
