Cameras will not sync after just purchased today. Support says to exchange unit?
I purchased a new complete 1080p set up with 5 cameras, after discussing with support and running through all of the obvious items support is designed to handle I was told to exchange the unit.. has anyone had issues with camera sync to the base? My phone and base communicate fine I just cannot get the system to synchronize a single camera...
@1-z,
Are you seeing the base station in your app?
I have had a couple of instances where using the app the cameras failed to sync. There is an alternate way to sync them. Briefly press on the sync button on the base then briefly press on the sync button on one camera. The LED on the camera should briefly flash blue for a couple of seconds then statr flashing blue rapidly. When the camera LED stops flashing rapidly, the camera should be synced.
If that doesn't work consider returning the system for exchange if that is possible.
Brian
@1-z,
Great to hear that you have it working now. I had never heard of that solution before, but it is good to know and thank you for sharing that with us.
Brian
