I have all the settings correct with my 3 cameras ie motion is definitely set to on. motion is on with the green man etc. Cameras are picking up movement and sending notifications to my phone but when I log in to Arlo their is no footage to play? I have 3 Cameras pointing at different angles on the same post out the front of my house (could they be getting interference been so close to one another?). I have only been getting issues with this for about the last 7 days or so with detecting motion and notifying me but they are not recording. Sometimes I might get a recording off one camera were I should have 3 recordings from each cam. I am thinking I might need to do a power down the cameras and re-sync?
Any suggestions?
Thanks.
PS: my cameras signal to the base is pretty much full bars give or take 1 bar at times.
Warnzie,
Are you navigating to the library to view the content after tapping the push notification? If it is an e-mail notification it should direct you automatically to the video but push notifications will only launch the app.
Interference is a possibility given the conditions you describe. Consider moving one camera away from the post with the other two to try and isolate if that is the cause. You could also try and relocate the base station itself.
Please let us know what you find!
Hi JamesC,
Yes definetly, navigating to the libary and nothing is there. I have double checked to make sure it is displaying all camera footage in the settings view. I usally will wait about 30secs before trying to view the footage but as mentioned nothing has recorded?
Its just weird that it was working all perfectly a week or so ago and now is playing up. Will try and reset all the cameras and re-sync if need be.
Same for me. Cameras detecting motion. Alerts sent to iPad and IPhone. No email alerts being sent however. When I click through to watch video from iPad or iPhone there are no videos. When I login on website there are also no videos. I have not changed any settings. Errors started around 12pm Australian EST.
Common Arlo Netgear lets get this sorted. At the moment my system is useless and shouldnt expect these issues with a $500+ security system.
Seems to be only effecting Aussie users only? Any other users experiencing this issue in a different country?
Worked momentarily last night and thought all had been fixed. However, tried again this morning and the same issue as already explained persists. After months of working brilliantly, right now my system don't work as promised - Arlo/Netgear are you working on a fix or at least able to tell us how we can fix our security systems? Thank you.
Same problem here for possibly the last 2 weeks now.
I have also noticed that i cant always connect and get a live stream to my cameras. Maybe works 1 out of 4 times.
Nothing has changed on my end. Hopefully the more people let Netgear know about this situation the faster it will get fixed.
I have had this issue from time to time for the 6 months I have had this system.
Yes seems alike this is a common issue that has gotten worse with time. I actually did just catch my cameras recording motion and a error come up saying "There was a problem establishing a connect to the media server" and after that error message no footage was saved/stored. Have now seen this do this twice now on different cameras. Nothing has not changed on my end at all. To me this is something on Arlos side with the "Cloud" and the base connecting to the arlo server. Where is a Arlo/moderator. How do we tag them in this.
just chatting to netgear/arlo person now. no solution yet 😞
Good work Beegee!! I sent them an email this morning. Let us know how you go.
Hi Warnzie, I directed them to this thread saying clearly others are having the same issue. They couldn't help any more right now unfortunately but have promised to get back to me with issue/solution. My system/setup hasn't changed in all the time I've had the system. Very frustrating.
Thanks mate! Yes it is very frustrating having a security system that doesnt work correctly as it should. Quite sure Netgear should have it resolved soon.. I hope :-/. Sick of getting notifications and there is not footage!
Yep, I'm having the exact same problem... as of about a week ago. I only have one camera, and it's located about 5 metres away from the base station... and has been working FLAWLESSLY since April 2015 when I bought it... up until a week ago.
I'm in Sydney Australia.
I hope this gets sorted soon - this is a security system... not a web cam for me to skype with my family... I rely on this for security, and it's completely useless at the moment.
Well, one of my cameras now appear to be working again (the other one I haven't re-set up yet after Netgear/Arlo requested I remove all cameras from the system and reconnect because of lack of time!). I'm getting iPad, iPhone and email notifications, and the videos are there too. It's consistently worked 3-4 times just now. I wonder if in the morning it will still be working. Let's hope so.
Netgear/Arlo said they would contact me when it was working again. It would be nice if Netgear/Arlo could do this AND more importantly also post on this forum to let everyone know what/if they are doing anything to help us get our security cameras back in order. We do have these cameras for a reason and when they're not working due to no fault of ours, they are 100% useless.
Look forward to hearing from Netgear/Arlo!
Seems to be working fine for me this morning... I'll test more when I get home tonight.
The app is loads more responsive today too... for the last week it has been failing to connect... saying my base station was offline / not connected to the internet, etc.
Fingers crossed it's now fixed...
My system is still working well this morning. So I also presume Netgear/Arlo has finally fixed the problem. Thanks Warnzie for starting this thread 🙂
