So this problem started when my base station stopped connecting to the Internet. I did the troubleshooting and eventually got the base station connected again.
now, I can get to the Netgear Arlo app and to the main screen but it says all my cameras are offline. I followed the troubleshooting procedures and they still "appear offline".
The batteries are good. The flashing blue light indicates that it's synced to the base station. The camera even clicks as if it's recording when I walk by. The cameras where armed before I had this issue and it seems like they are trying to work but for whatever reason, the base says they still "appear offline".
any ideas?
Disregard.
called customer service.
Beltfed762,
Are you still experiencing this issue? Please let us know.
Try restarting it using the power switch. What LEDs are what colors after the restart?
Joescafone,
This could be due to WiFi interference or poor signal strength due to range. Is it happening to all or just some cameras?
Consider relocating an affected camera with a camera that is behaving correctly to further isolate the issue.
Joescafone,
The extender could be causing an issue. Consider (temporarily) connecting the base directly to the router (rather than to the extender) to see if you get the same results.
