Am I missing something? Is it possible I messed up some setting somewhere?
Contrary to what Netgear Arlo wants you to believe, there is no fix. The issue is in the cameras themselves. Arlo recommends several "fix options" but as you've read, none of them actually work for more than one day.
Amazing that Arlo dosen't have the integrity enough to collect from the shelf . Instead, they continue to sell this defective product!!!
Avoid the Netgear Arlo systems until they fix their defective cameras!
I am still getting pink recordings WHEN I get recordings at all. My base station keeps shuting itself off and does not record as required. I can restart it with the Off/On button and it comes on again for a few hours then goes off again. I would like to return the defective camera as I have contacted you several times about the pink tint (11/26/16 Case # 27634726; 12/12/16 case # 27786226; 12/13/16 case # 27790383; 12/16/16 Case # 27764797; 1/2/17 Case # 27786226) I need help with both the bad camera and the balky base station. Thanks Tom
I have the same problem.... And this same comment is being stated by several people (wink wink Netgear....)
I have a love / hate relationship with my Arlo cameras....
Absolutely Love the wirefree ability (my cameras go from room to room)
Hate the 10 seconds or so that are lost before recording begings...
Hate that one of my cameras has red eye and that I may have to ship it and wait for return... (be without a camera while I wait)
So... it seems like there are a few more than just some bad apples (arlos) which were sold to good paying customers... Netgear should do better than just replace and make clients wait... I don't want to wait... Perhaphs explain the issue and maybe recall... You want trust, respect but more importantly loyal customers... please explain the problem and give us a more than fair solution.
Sincerely
Carlos H
It's a great idea. It's fair. I too would be willing to pay the difference. Cheers
Do we really have to send the old camera in first? Does it make sence that we have to create a gap in our security system to rectify defective equipment?
I turned turned my Arlo wireless over so it's upside down with the battery cover up. I then open the cover and let the camera turn off. Then close the cover so the camera powers up. Usually I turn the camera over and mount it... the pink tint comes back after the camera switches to night mode. The "fix" was to mount the camera upside down so the video feed is upside down on my phone. Then use the app to flip the image. To do that... log into your app, click devices to see your cameras. Find the upside down camera and click the little "gear" symbol that opens settings. Then click "video settings". Look for the "rotate image" and toggle it on. The video feed will flip eventually and everything will look correct when you view it.
Apparently having the camera upside down allows the IR filter to switch like it should. Stupid fix that should the design flaw.
However.. my cameras alerted me to movement on my driveway this morning and I chased a guy who was trying to break into my car away. Unfortunately he got away... but me running out of the house with a pistol probably gave him good reason to not come back.
It's the IR filter getting stuck. Do a battery pull and try give the camera a gentle tap. If neither of those work, get the camera replaced
one of my Arlo camera shows picture/vido in a rose color. just changed batteries, no help. suggestions?
Open a case with support using the Contact Support link at the bottom here. Lots of threads on this.
Why is my camera pink? I've already tried replacing batteries numerous times and resetting it! Nothing is working!!
Have you read the multitude of similar threads with the solution already posted? Search is your friend.
Since you already tried the battery door, opening a case with support is your answer.
Camera image turned pink. New batteries, Camera Off, I moved position, put camera in pocket, magnet in another pocket. relocated 2 ft away. and repositioned with magnet. image had tuned pink. How do I correct this?
This has been reported by quite a few persons on these forums. Sometimes pulling out the battery(s) and reinstalling them will reset the camera removing the pink tint.
And, as noted in the multitude of similar threads here, opening a case with support is what is needed to resolve a hardware problem.
I just purchased and installed the camera yesterday. It worked fine. This morning, the picture is pink. I've read the threads and apparently this is quite common. I reset the camera in all the ways suggested, and the picture is still pink. I've now replaced the camera with the second one in the package, which works fine at the moment. If it happens with this camera, I'm returning the entire product.
Or swap the system atnthenstore. Or use the Pro cameras which don't use the same IR filter.
