Am I missing something? Is it possible I messed up some setting somewhere?
Carola,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I had the same issue. I pulled the batteries out, then re-synced the camera which seemed to work.
It's the IR filter getting stuck. If this continues to happen, you'll have to open a case with support to get an exchange.
I already pulled the batteries multiple times
Carola,
Had the same problem with one of my cameras just this afternoon. I turned that camera off under "Camera On/Off" in the "Settings" for a couple of hours. Was normal after I turned it back on. Time will tell if that cures the problem.
I've just had two of mine replaced by Netgear due to the same issue. Once you log a support case, it's usually pretty quick.
Sure enough, the next morning when the sun came up, the red tint was back. Got ahold of support center to explain the problem and Marie gave me a RMA number. Returned the defective camera last week and the new camera is being shipped this week.
Great support from Netgear.
Can someone explain how to open up a case with customer support to get a new camera? Last person said just open the bottom up and close it (on the camera) as if I didn't try that many times.
Did you look at the bottom of the page as suggested? Big Contact Support link.
Jmango167,
I am not private messaging the solution, i've marked the solution posted above. Do you need assistance contacting support to further investigate?
This issue can only be addressed by support as it potentially could be a hardware failure (support will determine after you have opened a case).
Please read this thread - the answer is already posted. Contact support using the Contact Support link at the bottom of the desktop version of these pages.
U have to call net gear and wait to go thru their automated system. U will be on hold forever but eventually they will answer and set up ur claim.
If you are having the common problem with the red/pink pictures, please leave a comment on Arlo's Facebook page. Maybe then they will admit they are selling defective systems.
Hello, I have two sets of Arlo cameras in each of two houses, and I generally love them (when they don't have issues). I have 8 outdoor (arlo) cameras and 2 indoor (arlo Q) and one of each shows a pink tint to the image that makes it difficult to use. I have tried resetting by removing power/opening batteries many times, turning it offline/on, and even reset the whole system, but nothing seems to fix this. CAN YOU PLEASE HELP ME?
I tried to go to customer support but when I log in it says Error, so please advise how I can contact you.
Lasty, while I have you, is there a way to replace the batteries in the outdoor cameras (Arlo) without having to re-pair the camera with the base station? My outdoor cameras are in locations that are not easy to get to so I would love to just replace the batteries and not have to take it indoors to re-pair it.
Using the Contact Support link at the bottom of the desktop version of these pages gives you various options. I don't know what you tried (I assume email contact since I know that requires you to log in) but try another method or use a different browser.
Normally, replacing batteries doesn't require resyncing of the cameras. I've never had to do that over two years.
