Camera syncs but doesn't appear in app
  • 5985 Views
awvollmer
So I got 3/4 cameras to sync and show up in the app. The fourth camera however goes through the sync process, blinks blue rapidly, and never appears in the app. I have switched batteries, restarted and unplugged the base station, restarted the app, etc. What's going on?!
awvollmer,
If you are getting a rapid blue LED that indicates the camera sync was successful. Is the camera showing up under Settings > My Devices?
Larkus86
I have this same issue. Well, it appeared in my device listing when I first set up the system, then the next day - it said device was (something or other I can't remember the error message). But, I went through the synch process again - got the blue rapid flashing light again - and same error message. So I removed the device via the interface, re-did the synch process, got the rapid blue flashing light - only it won't show in my device list at all now. Batteries seem fine - other 4 cameras all working fine.
Larkus86,
Consider rebooting your base station (using the on-off button). Allow the base station to come back online with a solid green power and internet LED and then attempt the sync process again. Are you still seeing the same behavior?
