awvollmer,
If you are getting a rapid blue LED that indicates the camera sync was successful. Is the camera showing up under Settings > My Devices?
I have this same issue. Well, it appeared in my device listing when I first set up the system, then the next day - it said device was (something or other I can't remember the error message). But, I went through the synch process again - got the blue rapid flashing light again - and same error message. So I removed the device via the interface, re-did the synch process, got the rapid blue flashing light - only it won't show in my device list at all now. Batteries seem fine - other 4 cameras all working fine.
Larkus86,
Consider rebooting your base station (using the on-off button). Allow the base station to come back online with a solid green power and internet LED and then attempt the sync process again. Are you still seeing the same behavior?
