  • 4 Replies
  • 19680 Views
  • 4 Likes
Brusky
I have 2 base stations with 6 cameras and have already synced all cameras. I have 5 cameras synced to Base Station A and 1 camera synced to Base Station B. I need to sync one of the cameras currently synced to Base Station A to Base Station B. What is the procedure for syncing an already synced camera to a different base station?
Delete the camera you want to move from BASE A
SETTINGS/ SYSTEM SETTINGS/CAMERA ORDER
pick the cam you want to delete and click on the 'circled green X '
Then normal sync of cam  to BASE B
Beast
What if base b is now at a different location but already setup? Will this still work? I want to do the same thing at my vacation home but am worried I'd have to drag everything back to the same network?
Beast
I have three base stations- two will be at a vacation home. I'm thinking I may need to move cameras between the two new base stations but can't be sure until I get there. I'm hoping since the base stations are now setup on the same network I can at least move the cameras remotely when at my vacation home.
TBOMK, moving cameras between two bases shouldn't make a difference even if remote. The big thing is the original setup of the bases which you already did.
As long as the bases don't get unregistered, i don't see a problem.
( as to real world, I will say I haven't try that yet tho ) so obv do one to test first
