Whenever I open the Arlo app on my Android phone I'll get notification saying motion was detected and one of the cameras will start recording, but the fact is there's no motion at all. The app version is 2.2.0_14738 which is the latest, but this problem happens for previous versions as well. Thanks.
I have had this happen every now and then too ( Android as i dont arm with IOS )...
Usu it is the camera that has a lot of light in the room , like the patio doors. It only occurs now and then and then only right after arming.
I think it may have something to do with the prev PIR info and then becoming active when armed and "seeing' a difference that triggers a false alert.
It has been mentioned before so to put it in the genne pool again , you could put in a trouble ticket.
Is the camera actually recording? Do you see a new clip in the library when this happens?
Consider removing the affected camera from Settings > My Devices > affected camera > Remove Device to and resync to see if you still get the same behavior.
Yes the cameras were actually recording and new clips were added to the library -- just like there's new motion dectected, but there's no motion at all when I opened the app. I've removed and added cameras before, and I also added a new one, so removing and adding does not solve this probelm.
This might by a different issue, I also noticed after I modified the camera mode on web page (i.e. set recording time for one camera), when I click "save" the cameras will start recording, as if they detected motion.
debugger919, dehn001
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
