Hi there, one of my cameras is now experiencing the Purple/Pink video problem, right, i talked with support and they told me, I need to send to replace and wait to they receive it and then they will send another one, AND... I NEED TO PAY THE RTES FOR THE SHIPPING TO NETGEAR (unexplicable but real). The system has 3 days since I bought it so, better, I'll go to Best buy (the place when I bought it) and I 'll exchange for another one or maybe another system cameras.
Incredible but truth... pay for sending a camera that does not work... WTF!!!!!
danymaker,
I apologize for the poor experience and would like to help assist you with this issue. I will reach out to you in a private message to further investigate your support case.
No need to investigate... true or false? to send and pay the shipping costs? (i mean the sshipping costs to netgear)
Currently, any method you choose to get an Arlo device replaced via RMA will cost you to ship the device to Netgear.
Dont worry. I returned it to the shop, Best Buy, free, and quick... they fix my problem, you didnt. Pay, for return a new camera to netgear... no mames!!! wtf!!
Also my cameras at times during the daytime records in b/w...any suggestions?
Pull batteries then replace to reset camera... it if doesn't correct the problem then
contact Netgear for a possible replacement... the red view is the IR filter stuck on
As to just B/W... the camera auto switches to B/W when the light level is low... no user control over this ( other than maybe the iris adjustment )
