Camera placement
I have a camper trailer that I attach to my car occasionally for travel, I normally keep arlo cameras around it for safety but now im wondering if I can keep the cameras on when I drive.. I dont want my cameras to fall off or be damaged as theyre quite expensive and already part of my setup so im wondering if anyone has any advice?
Note: theyre attached via a strong magnet which is screwed into the frame of the trailer. I could screw the cameras to the trailer directly but then id loose the ability to angle the cameras in the most optimal way so I really dont want to do that nd would rather continue to go through removing and reattaching for every trip. Any advice or information would be helpful!
The cameras fit on to a "standard" camera mount you can buy almost anywhere.
Find a secure adjustable mount you can fix to the trailer and use that.
example ( but maybe not what you want )
https://www.amazon.com/Adjustable-Essential-Generation-Mounting-No-Drill/dp/B0CLV6FF1P
