Cuban271 wrote:
Wasn't asking for details of their security plan just wanted to know if they had a system in place to try and stop hackers. Like any type of firewall or anything like that.
The data stream is encrypted with a key coding
1. As is repeatedly shown, nothing stops detrermined and talented hacker.
2. You really expect netgear to detail you their security features to make it even easier for hackers to get into storage.
Netgear like other companies does their best but no cloud storage is hackproof, so if this is critical to your needs avoid a system that stores to the cloud, but then hope nobody hacks into your computer where you've got your recordings stored.
If I understand right, the Arlo Pro stores to your local usb storage attached to your base station before it stores to cloud, but I don't know if uploading to cloud can be turned off.
