- 2
I know this has been covered. I just added two cameras to my five camera system. I have tried everything mentioned the knowledge base. These two cameras will not update. cycled power on cameras, base station. Deactvated base station reactivated it. Reset base station with auto update on. I am hoping they will auto update will work during the night.
check that the option to 'record video' when 'motion is detected' is checked in the settings of the mode you are using...its only checked by default in the 'ARMED ' mode
Also make sure the filter in the library isn't set. The "funnel" should be empty/white. If green, reset it or go back to the Devices tab and click on the number displayed for each camera to view only that camera's videos.
Open a case using the Contact Support link at the bottom here.
I have one camera already set up and we can view what it is doing. We decided to set up the second camera in the box. It seems to be in an endless loop of updating. I keep getting emails that there is activity on the camera and I can even see the videos taken on my email. I cannot view the camera on my phone. I CAN view the first camera perfectly.
Can you help me with this?
Thanks...
Power cycle the base and open and close the battery door on that camera when no LEDs are lit. If that doesn't help, remove the camera in Settings, My Devices and resync. Any luck?
Just purchased VMS3230C-100NAS.
2-camera system.
1 cam was updated and working fine.
However, 1 cam is not updating firmware hence can't view live.
I'm trying to find the suggested fix SETTINGS > BASE STATION > TOGGLE AUTO UPDATE but i cant seem to find this page.
Saw a reply that this field was removed?
Currently, 1 cam (SN 4WA16B7B7A7DE) showing the latest SW 1.2.10342.
But the one having issues (SN 4WA16B7N76F27) is still showing SW 1.2.9561.
Need help, please. Thanks in advance.
- Wait overnight for updates to occur automatically
- power cycle the base and open and close the battery door to reset the camera and see if an update is then available
- reset the base by removing all devices in Settings, My Devices and start fresh
Thanks for the suggestions.
However, i've tried all 3 and still Cam 2 is not updating hence i cant view live.
After i remove and replaced the batteries, at first it says UPDATE AVAILABLE then when i click on it, it just stays that way.
Next time i check, the cam now says "NOT CONNECTED TO INTERNET".
Does anybody having the same issue?
TIA.
Can not get my game a to update just got it very upset
Gilbertarnett83,
What are you seeing that is indicating an issue? What firmware version is showing up for your base station and cameras?
Where is the Auto Update in the program?
No longer a setting - it just is. You can attempt a manual update if one is noted as available by going to Settings, My Devices, your device, Device Info and see if you can click on the firmware section. Otherwise, power cycle the base and reinsert the battery in the camera to have them update automatically, usually overnight.
This morning I connected a 4th wireless camera to 5 camera system and the firmware will not update. I have tried removing battery and reconnecting. I have tried also removing profile from system then adding back. Help!
- 2
