I guess it's possible the person didn't knock on the door but something else? In any case, test motion detection yourself at various times and settings to ensure you get a recording. You don't need to wait till 2:45Am - just total darkness should be fine. You may find that you need to create additional custom modes for different times and then schedule them.
If you edit your camera Rules for Armed and set the motion sensitivity to 100 for them all (and save the change of course), they will record everything but you may get a lot of false activations and your batteries will drain very fast.
What I suggest to people is that they set their sensitivity to 100 to start with and turn it down 1 every time they get a false triggering within say half an hour of a previous one. This will allow you to get down to a level that's low on false triggers but captures everything you need to be recorded. It can take a while to fine tune each camera to its position
I can walk or drive by the camera 15 times,,,and it may only record once or twice. also, it does not always trigger at the same spot.
first question would be... at what distance from the cam.?
Also what sensitivity setting and are you walking across cam or towards cam?
A screenshot of the camera view may be helpful, too.
