Hello,
Spectrum just changed my modem and my Arlo cameras will not re-sync.
The Netgear VMB 3000 works and appears on my MAC when I connect it.
I follow the process to synchronise on camera:
1- press the Sync button on the side of the server. SYNC flashes.
2- Press the Sync button above the camera, standing near the server.
But nothing happens. The camera won’t start - no flash blue or amber.
I have put new batteries. I have even changed the internet cable and reset the server.
What should I do?
Thanks.
Move the base a bit farther away from your main router... as far as cable allows
pull battery on camera to reset same
QUICK press on base unit sync
sec later the camera sync
