Camera appearing offline
Arlo cameras were working fine for months. Suddenly one camera go off line. When checking camera all cameras suddenly went out. I could never get smart hub back up in the Arlo app. Front light is blue but will not connect. Tried factory reset and still will not connect. Any suggestions.
A factory reset requires that 1) you hold the reset button for >10 seconds until the LED starts flashing amber and 2) you remove all devices from your account and start fresh, as if you just bought it. Have you done both things?
