Tampering
I have a doorbell - outdoors and I need to connect mine to others - how do I do this. My connectivity for my internet is continually tampered with too - I'm with verisure and the whole system is tampered with, signal shut down.
what do you suggest, when I go out the doorbell is temporarily stalled. I need help with. I have residents actively supported by police able to access my home on repeat!
How do you know about the tampering?
Unless you've provided anyone with access, either using your account or you've used Settings, Grant Access to anyone, no one should be able to access your system without a warrant or other permission from you.
We need all details to try to figure this out.
Since the system is supplied through Verisure, you need to work with them. We have no idea how they have integrated Arlo into their environment. As for the Internet connection being "rewired" (not sure what that means), that's an ISP issue. I would also ask the police for help since this seems to be a much bigger issue than Arlo.
You can add people for access to your system by using Settings, Grant Access. They won't have full control even if the additional Access Rights are provided to them but it's close.
