Camera Offline vmc3030-100nas
  • 4 Replies
  • 3004 Views
Letivamp
(White wireless magnetic motion detection night vision format:h264 850nm LEDs field view 130• waterproof IP65) All 3 cams were working just fine until 1 needed battery switch...they all stayed offline after they were resynced. Tried reset and on/off button still all are offline. Please help!
What LEDs are showing on the base and what color?
If you used the reset button, you're going to have to delete all devices in Settings, My Devices and then use the Add Device button in the Cameras tab.  Add the base and resync cameras as if you just got the system.
Hughie
It say camera is offline ?? What it mean ?
It can mean various things, from dead batteries to a network or server issue, as well as the base being confused.
Hughie,
More information is needed for us to understand why your camera is offline. First, I recommend opening and closing the battery compartment door on the camera and paying close attention to the camera LED: What do the different LED behaviors on my Arlo Wire-Free camera mean?
As jguerdat says above, it could be a battery issue, try installing a fresh set and see if you get the same behavior.
