  • 2440 Views
dylanthology
Dear,
I have 5 cameras, 2 pro’s and 3 normal Wire free cams.
Al off the cams are working correctly except for one of the wire free cams..
I did change location, change batteries, reset,.. everything I already tried, but when I connect the cam to my base station he is visible for 10minutes straight and then ‘offline’
is there something wrong with this cam?
Thanks!
It is possible something is bad with the one camera...
But ,what I would do is use Remove Device on that one camera, pull battery/replace, then bring the camera back as new... this will rebuild all the info in the base for that camera.
Also, you are using OEM cells or 3.7v li-ions in that Arlo?
dylanthology
Thanks for your comment!
I already did try (several times) to remove that specific camera and than bring it back as new.
The cam is connected than and after a few moments he is going offline..
I use the normal batteries from duracell CR123 lithium 3V
ShayneS
HI @dylanthology
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
