Calendar Times Not Sticking
When I try and set the different on/off times on a given day, it only ends on 11:59 pm and won't keep the time I select. Example is I want it on between 12:00 am to 7:30 am. Off at 7:31am to 10:00 am. However it doesn't stick. Instead it sets it as off 10:00 am to 11:59 pm. I'm unable to st multiple on/off times on the same day.
Schedules are turning on MODES automaticly... remember that ONLY ONE MODE can be active at a time.
If you want multiple on/offs, you may have to create new MODES that fit what you want to do.
