New day same $&@@
From what I remember , your system is resetting?? Do you keep track of your s/w version by any chance?
Obv, the re-set, thats not normal and may have something to do with the updating s/w screwup. A full reset puts it back to the factory settings and rom may carry older s/w ( not sure on this )
But, I 've been running a newer version like MAge99.. base is at 1.4.2695 and cam is 1.2.2688.
So netgear is working on the problem, as their testing newer versions.
I have seen some 'sluggish' behavior, but non-of the major problems you seem to have ( and I did run thru the older versions you have now )
Just went and tested 18 videos outside at bird feeder... all running/motion detect as normal.
I really think they'll get on this quickly with the problems popping up.
Showguy wrote:
Actually after I reset all the settings AGAIN the system seems somewhat stabile. Recordings are going to the library, motion is working and streaming although sluggish is working. The base software is still at 142627 and the cameras ( as you can see from my post above) are running 2 versions. I've decided not to try anything until Netgear figures this out.
good to hear...
the reset thing has got me thinking tho.... why,does it reset... are you the only one it re-sets on?... It shouldn't be the s/w ... the versions you running now are 1 and/or 2 back . (They release these in small amount first to minimize problems like this.)
If I were doing this and the resets continued( yes prob a pain for you ), I would think of possible maltfunction of the base...last time I had a router keep resetting due to internal overheating...drove me crazy too. I think you mentioned you have a spare base too.
I'm hoping this issue gets resolved soon. On a positive note, I was just able to stream all 4 cameras live on first attempt of connecting. I then disconnected and tried a second time, and they all connected right away again! My firmwares have not been updated, still at base 1.4.2627 and cameras 1.2.2545, so it leaves me wondering if these connectivity issues may be network related on the remote server (Netgear's end?). It will be nice to know if these issues are firmware or network related although either way, I think I'm going to turn off the Auto-update firmware feature (once the system is stable).
