CAMERA GOES OFFLINE
Took ages to find a phone number...
Took ages to get through on a call...
Only to have the tape go quiet, and nobody talks! Not happy!
@SIB7 wrote:
And I don't know if that's the right camera number
Does your camera use four CR123 batteries? Or does it use a rectangular rechargable battery?
@SIB7 wrote:
Hi I believe they're the rechargeable CR123 ones, not rectangular., They're short cylindrical shaped.
Then you picked the correct model.
Thank you 😊 @StephenB
We can't think why it keeps going offline. We've moved it so that no solid structures above it. I'm needing to charge it up and/or re-sync it.
It's not more than 300 ft away atall. It's about three car lengths away.
@SIB7 wrote:We can't think why it keeps going offline.
If you have a second camera, try swapping them, and see if the problem stays with the camera (or not).
300 feet is a fair distance from the base. Is it possible to move the base closer? Or is that not practical?
HI @SIB7
