  • 10 Replies
  • 3701 Views
SIB7
Camera keeps going offline...
Took ages to find a phone number...
Took ages to get through on a call...
Only to have the tape go quiet, and nobody talks! Not happy!
10 REPLIES 10
SIB7
And I don't know if that's the right camera number
Does your camera use  four CR123 batteries?  Or does it use a rectangular rechargable battery?
SIB7
Hi I believe they're the rechargeable CR123 ones, not rectangular., They're short cylindrical shaped.
SIB7
This particular camera is in my neighbours garden, which is just across a couple of parking spaces
Then you picked the correct model.
SIB7
Thank you 😊 @StephenB
We can't think why it keeps going offline. We've moved it so that no solid structures above it. I'm needing to charge it up and/or re-sync it.
It's not more than 300 ft away atall. It's about three car lengths away.
If you have a second camera, try swapping them, and see if the problem stays with the camera (or not).
300 feet is a fair distance from the base.  Is it possible to move the base closer? Or is that not practical?
SIB7
I swapped the cameras but it still goes offline whichever camera is over her garden. I've got my camera back now because gave up having to keep resyncing it.
SIB7
Thank yous anyway 😊
ShayneS
HI @SIB7
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
