  • 2 Replies
  • 6437 Views
vetrijar
Using the phone app for Android (droid turbo), I'm getting a Busy message to the right of the Motion Detection Test and Position Mode options that are under the Adjust Settings.   Not sure what is going on. Last 2 times this happened to me is when I pressed the Position Mode on the app.  When I was done positioning the camera (long lag time if that is normal?) I would back out of that area on the app. That is when the "busy" text appears.
Is this normal? If not, did I do something incorrectly to cause it?
Thanks!
How about if using the app? If both, you may have a failing camera. I recently had one replaced that did this (among other symptoms).
XipperPDX
In my experience you have to forcequit the app and re-open it, it is surely due to a very bad design on their part.  I hae also seen a lot of problems getting errorss like the one attached.  IMG_6257.PNG
