Bridge Connection expand range
I have the 3 Wire Free Security Cameras by Arlo and need to expand the range to pick up a camera from the HUB, the only Bridge I see available is for the Security Light. Please advice on how to increase range...
If you can't locate the Arlo Base Station in the most central part of the building relative to the cameras and/or the cameras are too far away, you'll need to get another base station. The base stations require an ethernet connection. There's no limit to the number of base stations you can use and all the cameras can cross trigger regardless of which base station they're connected to. Each base station can be set to a different mode so it can actually work out more convenient than having to create a bunch of different modes on one base station
