Bought Arlo cameras less than a month ago. Supplied batteries are fully discharged after 3 weeks
Less than a month ago I bought Arlo cameras. The supplied batteries are fully discharged after 3 weeks. They normally have a lifespan of six months. The cameras are switched off and one times a day consultated. Who knows what to do?
What camera models did you purchase? The original wire-free that uses CR123 batteries or one of the newer models with rechargeable?
Battery life depends on how much video your cameras are recording. If you are turning off the base station and leaving the cameras turned on, then you are hurting your battery life - not helping it. The cameras will end up continually looking for the base station.
I've never had mine last 6 months - generally I am seeing 4-5 weeks. If yours are triggering more often, then 3 weeks is certainly plausible.
If you are using the wire-free then I recommend getting the rechargable Tenergy setup that's compatible with Arlo. It will pay back fairly quickly.
