hi,after I installed 2 sets at home ,how should I instal another set at my shop on the same iPad ?
thanks
You can easily use the two as two separate systems as long as you use a different email address for each one. If you want to combine them to use one email address, hence one login to check both, you'll need to use one of the paid subscriptions.
