Both of my Arlo systems show nothing for 7/5/2016
  • 1 Reply
  • 2239 Views
MSMusial
I'm seeing nothing for today, 7/5/2016, on both of my Arlos systems using the phone app or the web interface. Both are online and active. Live view works. Camera view has images from today, calendar shows the 5th but can't select it.
MSMusial,
This indicates that there are no recordings captured for 7/5.
Check to make sure your system is Armed. If using a schedule, check to make sure the correct modes are set within the time frames you would like the cameras to detect motion.
