Blue flashing than orange - tried 20 times to reset
I have a new base which I try to connect to my camera:
Another camera of the same type is connected, also a Pro 2. Tried to connect without the bridge being connected to the internet - over the sync button with the same result. Tried with new batteries and after taking out the batteries for a night.
Any ideas? Thanks a lot!
Hey 24ax,
If your cameras are showing a fast blinking amber LED, it means it's failing to sync with the Base Station. You can read here to learn how to troubleshoot: My Arlo camera will not sync with my SmartHub or base station; how can I troubleshoot it?
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Let me reach out to you via private message to gather more information from you since you said you already contacted the support team
After thousands of attempts, I've done everything, changed the battery, already reset the station ... I did everything possible but one of the cameras does not synchronize. always gets the Amber Light quickly. I can't synchronize at all
