Battery life Arlo
  • 9 Replies
  • 15926 Views
jimvaughan
I have two cameras, both use the same battery and I have tried switching locations.
One camera (no matter which location it is at, I have tried both cameras in both locations) has normal battery life (months) the other lasts a few days.
Is this one camera faulty?
Both cameras are hardware H7 and 1.2.16720
9 REPLIES 9
brh
@jimvaughan
The batteries should last for more than afew days if you have swapped locations with the other camera and they are set up the same way. Is the camera under warranty? If not these cameras are selling for a lot less money than before at most retail stores.
Brian
steve_t
Master Master
I'd suggest contacting support
jimvaughan
The response from Netgear was, it's out of warranty...
steve_t
Master Master
Bugger.
Ah well, silver lining is you could get an add-on Arlo Pro camera that is superior in every way.
brh
@jimvaughan
On further thought you are mentioning one battery, but in your tags it says you have the original Arlo cameras that use 4 batteries. Which system do you have?
Brian
steve_t
Master Master
H7 Hardware the 6720 firmware - they must be Arlo HD
brh
@steve_t
I wonder if 2 of the batteries are not making proper contact. Common problem with these cameras.
Brian
jimvaughan
Let me look at the contacts, that is a good idea. Yes, I have the 4 battery model. When I referred to same battery I meant same battery type.
brh
@jimvaughan
These cameras are set up to use 2 banks of two each batteries in parallel. The camera switches back and forth between the two banks. Therefore the camera can run on only two batteries, but their lives are greatly shortened. A common problem with this model is that two of the batteries do not make good contact, forcing the camera to use only the other two batteries..
Open the door and remove the batteries. When reinserting them, let gravity drop the batteries into place. Then close the battery door and allo the door to put the proper pressure on the batteries to properly seat them.
Brian
