  • 1 Reply
  • 1731 Views
duckson
Previous thread was deleted so trying again.....Arlo saved me tonight from an attempted break in so want it working if at all possible!!!
Since the last firmware update the battery levels are reporting upper 90 percent when in reality they were reported as 60 odd (been in use for 3 months so expected to be accurate).
Rebooted base station, resynced cameras and removed cameras and re added to system but they are still reporting battery levels in the 90's.
Seems there was a problem with battery reporting being incorrect from 18 months or so ago that was fixed, has the problem been unwittingly activated again?
NTMK,.... the battery levels seems to be tracking fairly well now as i have one cam reading 47% and never use to. ( it would hit 55% and then read 15% sending email ).
A few others have seen the battery levels go up after the last update so I wouldn't be worried so much. But, time will tell and just keep an eye on it.
BTW, cam sw is now 1.2.7730  /  base is 1.7.8.7427
