Since last week the battery level stuck at 96%.I try to "use" the camera using live view or motion detection but the percentage does not change.
Ps Sorry for my bad english
Take the camera and then Open the battery door for a few secs, then reclose.
Make sure the camera re-syncs ( by the flashing blue then fast blue flash ) on led's
See it it changes anything
I remove the batteries and now is even worse.It shows 100% level!!
The battery level readings ( tmk ) were part of the last SW updates... Yes, it is a possiblity that now it reads 100% as the removal and replacement as the unit sees it as a new set point for the level....
But in the real world, 96% to 100% isn't much and I believe it will settle out... just keep an eye on it
What I would do is go and check now and then in settings for the change of %
As I mentioned earlier... since the new sw, it's been tracking pretty accurate
Today the level is 98%.I will keep any to see the changes
Thanks for your assistant
