Battery issues
Hey- so battery status on one camera kept saying low. After reading some threads on here I replaced batteries, re-synced it to the base station. Worked for 5 mins & then battery status reducing as we speak. I've tried to do an update but says updates not available. I've gone through 3 x of batteries for this one camera (my other camera is perfect). Please help, thank you
Is this a GO or different model??
Either way , contact Netgear support as you may has an issue with hardware
ajtindall,
It could be a location issue. Try putting the camera in the same location as the camera that is behavior correctly, do you see the same behavior?
