Battery indication
  • 1 Reply
  • 3008 Views
ohayonguy
Hello all,
I wanted to ask if somebody knows how does the Arlo's battery indication works?
Does it measures voltage and estimates the remained capacity? Does it uses columb counter?
If I am using primary 3V batteries, than the voltage curve is different than if I would have used the rechargable 3.7 123A batteries. So how can the Arlo tell how much battery capacity is remained?
I plan to use a large battery pack (about 20Ah) wired to the Arlo, so I want to make sure it will know how much battery capacity is really remained (if it uses columb counter, than it wouldn't work well :()
Thanks.
Good question...
TBOMK, it seems to use the voltage sensed at time of battery placement and then that is set against a cutoff voltage level... I also guess it's using two different ' data sets' to that end ...which is why it can work with the 3v ( actually 3.2v when new ) and the 3.7 li-ions ( usu about 4.18+/- to 4.2 (when off charge )) Cam cut off or warning to replace OEm cells ( about 10% ) on the cells is 2.75v-2.8v  ( think its 3v on the li-ions not 100% sure )
I have run the Arlo on a large 6v gell cell but at that time It was being recharged by a solar panel with a simple LM317 chip circuit s a regulator... so I can't give you much info on just a large pack.
I would just use the normal info we have and base you aprox life on that data.... Max current is just about 250ma +/- and usu half running at 150 +/- ma  when live... and the internal OEM primary cells have a capacity of 3000mahr.
For me the OEM last just about 4 months on best video so a simple calc would say a 20ahr pack may get about 2 years of SPEC usage.. ( not counting for self-discharge, etc )
Interesting to see how it works out for you... PM if any other questions
