Batteries need replaced after 3 weeks of use following purchase
I have the latest firmware installed and only got 3 weeks of use out of 2 of 4 cameras. The Netgear indicated that you should get about 3 months of use out of the batteries -- I would say that it somewhere where the camera is triggered once every few days and not at the front door of your house which is triggered 4-5 times per day.
Anyone have any ideas why the batteries only lasted 3 weeks? I can reduce the recording time by 60% so that should extend the battery life by a proportional amount.
Given the 2 cameras with low batteries is located where I get the most activity outside the house, I suspect the recording time is the culprit.
Spec usage is 4 mins per day at optimized video settings.
Running under best video quality and < spec use, I get 4 months ( up to 7 months on very lightly used cameras )
Make sure you adjust the sensitivity to a level where it only picks up what you want. I was initially recording 3 times as much due to cats and seemingly nothing at all.
You could always rig up a power supply to the main culprit if you are happy with its location
Image quality will not improve due to signal quality/distance. In the digital world things either transfer at original quality or they don't....they won't degrade.
